Hi all:
Well, I had a very unpleasant surprise today that I thought you might benefit from, particularly if you have one of the packaged, throw-able life rings on your stern rail. I will not mention the brand name as I believe there are multiple companies supplying these devices. Also, my issue was in no way the fault of the supplier.
I have owned two of these systems on different boats over about 20 years. Fortunately, I was never in an emergency requiring deployment of the system. The container on my present system had deteriorated over 12 years so that it was an eyesore. I discovered that I could purchase a new container without the entire system, and did so. Today I planned to swap the flotation device from the old to the new container. What a surprise! The flotation device was firmly stuck in the container and I was unable to pull it out. I finally simply cut the old container apart and rescued the flotation. Had this been an emergency on the water I could never have deployed the device! It had never occurred to me over all these years that the system needed maintenance in order to remain serviceable in an emergency. I'll bet the instructions said so, but I never looked.
So from now on I will maintain the system in the spring, and in mid season. The maintenance will simply consist of pulling the flotation up and out of the container to ensure that it is not frozen in. I will also lubricate the flotation with a bit of dry lubricant.
A word to the wise......
Rick
Rick
