MOB for Real
Mar 26, 2011
4,015
Corsair F-24 MK I Deale, MD
In shore racing is one thing. Been there, done that. Never fell off, but took risks. Sure.
The MOB recovery record off-shore in rigorous weather is not comforting. That's not a criticism, that is just a realist recognition that everything is against you. Many people have pointed out that off-shore the edge of the deck should be regarded as a 500 foot cliff, with waves washing across. Iv'e done perhaps 20,000 miles of solo sailing, on this and larger boats--no chance of MOB recovery. You simply avoid washing off a 500 cliff. My other hobby (35 years and counting) is rock and ice climbing; we do some crazy looking stuff, but we really don't take many risks, because real risk is stupid. It catches up with you. I understand working with tethers is a pain, but they need to be used AND they need to be used properly, which means extra clipping points and often keeping them short. As we have learned MANY times, if it's long enough you can go over the edge you may die anyway. So don't go over the edge.
Gunni
Mar 16, 2010
5,937
That dude, Val, is so ridiculously lucky to be alive; he should be playing the lottery every day! 15 knots downwind at night with the kite up and an inexperienced crew, none of them wearing a PFD or harness?
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
This is an interesting event and I have heard the personal account several times from the MOB himself about this event. My wife and I are in the process of purchasing a Dan Buoy for our boat.
http://www.forespar.com/blog/tag/newport-to-ensenada/
Farr 40s are one of the most aggressive & rambunctious group of racers that I have worked with. These guys have been known to race like they are playing bumper cars. It can be like a Wild West event with these guys on a good day.
SFS
Aug 18, 2015
2,100
Currently Boatless Okinawa
Has anyone tried a Life Saver? It seems like an easy to use, always available solution, for about $25 per person.
http://moblifesavers.com/
I first became aware of it watching videos from Duncan Wells ("Stress Free Sailing") on Youtube:
203
Caliber 40 LRC Lake Pueblo
Maybe its the kayaker in me but I am not a fan of a loose bit of rope hanging off of me.
Too many potential dangers of entanglement there for me.
Rick D
Jun 14, 2008
7,206
That must have been the 2014 race. I had a similar thing happen at the same place. I was below. Crew lost it and got pinned and had brain shorts about releasing sheets; hollered for me to come up. Hands and knees I got up and helped get the boat back on her feet. Got hit by one of the slop seas and she went back on the rail before she had stabilized. Almost went under the lifelines and banged up my arm pretty well on the winch. I would have been dead; no way the crew could have responded. However, that did get me thinking about MOB gear. The traditional gear is useless unless you have a crew that has trained extensively. I got a Dan Bouy and she rides on the rail whenever we're out. Better chance someone will remember to simply throw it and the MOB to have something to hang on to and a frame of reference to return to. One more tool in the bag. But, chances still are you fell off a 500' cliff.
SFS
Aug 18, 2015
2,100
It only deploys when the autoinflating PFD goes off. Otherwise, it is tucked inside the PFD. It's also floating line.
Anyone have any experience with this (British) product?
I haven't seen anything for solo sailors that connects a drag line to the helm in case of MOB.
Maybe something that allows sheets to be released and the helm pulled had over if MOB grabs drag line
- Will (Dragonfly)
Oct 30, 2017
203
So the floating line deploys when I hit the water.
The rescue boat over shots me and goes over the floating line... fouling on either the keel bulb or prop (because lines never get hung up there)
Floating lines float in clam water. All bets are off when it is not calm. High action seas over coral?
Still not gonna work for me.
I would rather have my crew prepared otherwise.
Aug 22, 2017
1,609
- Will (Dragonfly)
For deliveries, I rigged up a Fell Marine MOB+ unit to a loud horn. This way, if the helmsman goes over in the middle of the night, the rest of the crew gets a wake up call immediately.
This same gizmo could be rigged to an auto-helm or some type of sheet release gizmo to get the wind out of the sails. It could also be rigged to deploy a big sea sock or a trailing line with a float, or even a life raft.
The MOB+ is normally used as a remote kill switch on motor boats. If the guy wearing the bracelet gets more than 50' from the base unit or if the bracelet goes 1' under water, then the base unit trips. Since the output is a form C (SPDT) dry contact set, you can hook it up to almost anything. It doesn't need to be just a kill switch. The device has been marketed as an improved Autotether, but I have found that it can be effective for off-label uses as well. The mother company is very responsive to customer questions & other issues. They have been great to deal with.
Jul 29, 2017
169
Catalina 380 Los Angeles
I'd like to add a personal comment/observation here. As with any accident/incident, Val went overboard without a harness or PFD due to a chain of events. Had any one of those events been changed the outcome would have been different. He was and continues to be an incredibly lucky individual. Had he been clipped in the outcome would have been different. If he had taken the time to put on a PFD the outcome would be different. Had the time of day been different the outcome would have been different and so on and so forth. The 5 things I took from this are as follows: Always clip in at night, always wear a PFD when on deck, remain calm, A DAN BUOY can certainly be a lifesaver, and it is difficult even with a swim step to wrestle someone who is partially or fully disabled back onto a boat even with numerous folks helping. Our boat is equipped with a life sling and a fully operational hoist at the stern of the boat with our swim ladder and swim platform at the ready. Still I would not presume that it would be easy to lift someone fully clothed and wet, tired, injured or hypothermic back on board. Stay safe.
Nov 8, 2010
11,386
A key point here. In any type seas the stern is the absolutely WORST place to try and bring someone back on board. If anyone is relying on a swim ladder for open water MOB retrieval, you should think again. Any type of wave action makes it a very dangerous place.
Aug 22, 2017
1,609
I think that varies a bit depending on the boat. In the case of my open scoop transom Hunter, I brought my MOB back in via the stern. I think that it was a good choice in that particular case. I agree that in many other boats this may not have been a good choice of entry point.
Nov 8, 2010
11,386
My point is, in waves the lower edge of the stern slams up and down into the water with great force. Crazy danger. The side of the boat, without the hard edge, present nothing like that. Stop your boat in a moderate to heavy seaway and look at the transom, and image trying to get on.
EDIT, oh an open transom 21 footer. Maybe OK.
Likes: thinwater
Gunni
Mar 16, 2010
5,937
Yes, the stern, whether or not it has a swim platform will be bucking up and down viciously because you have the boat stopped to bring your MOB onboard. You have to plan to bring them on in the beam slick you have created with the boat. Again, go out and practice your MOB recovery, that should lay bare the hoo haa from what works.
Jun 11, 2004
1,935
Oday 31 Redondo Beach
+1. Even when just swimming off the boat at anchor in a less than calm cove I have been nervous about using the transom ladder. The stern looks real big and heavy when it is bobbing up and down inches from your head.
:plus:My wife and I got our children certified in Key Largo, WAYYYY back when they were 10 and 13. We dove off the company's dive boat. Even on a beautiful calm day, the swells made the stern dive platform challenging. As a kid, we had a folding ladder we hung off the side of our schooner, never had that much trouble.
The best reason, I can think of to use the side ladder recovery is maneuvering the vessel for the pickup. When you approach the MOB, you try to put the MOB on the leeward side before heaving to, so the boat isn't drifting away for the MOB. Boarding from the stern puts the vessel past the MOB and makes timing more critical. On the other hand, if pointing into the wind, the leeward side is the stern and if you are in irons, you shouldn't drift away.
Of course it's all about the orientation. On those rare occasions when the wind and the waves are not in accord, it is going to be hard pointing into the wind and climb the sides of a rolling boat. Sometimes the waves, roll can help lift the MOB too.
Here's a link to a site that compares 4 MOB maneuvering methods. It is an interesting and informative read.
http://sailingmagazine.net/article-1343-crew-overboard-recovery.html
The best point is practice practice and practice because calm heads are the best path to success and familiarity through practice is the best way to get calm heads.
I have never been involved with a serious MOB. I fell off my hobie 18 with a friend at the helm. the pontoon wing and I went up and the wing wasn't there when I came back down. I was more concerned, in the warm Gulf waters, about losing my glasses. My friend was/is an experienced catamaran racer and hobies are very maneuverable and easy to climb aboard. We practiced aboard Sunflower when I was a kid but it was more of a nice day to go sailing and swimming. The lectures about boat maneuvering were just theoretical. They were only practiced by the captain, my father, who never played the man overboard. In the 70s a harness was something that took up space in the cockpit locker, right alongside the life vests.
-Will (Dragonfly)
Oct 30, 2017
203
I have to say this about product in the OP video....
if I had one of those on my boat it would be being used more for fun by my friends. So much so that it would probably need to be replaced before it was used for it's intended purpose.
Just one demonstration of what it did and how to use it would be all it took. I'd have friends "falling off" repeatedly :)
