Mk I side ports
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
Hello folks,
So, we have an '83 MK I. Has anyone replaced the fixed side hatch in the head with an opening hatch?
Thanks,
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Mine came with a slider and I put in a fixed tinted port. Slider would leak. I would remove the old and measure the opening and order a real port. Should be pretty easy. Now you have me thinking, a breeze in there would be nice.
Nov 14, 2013
238
Yeah, that was plan B. The lazy in me was hoping someone had already done this and I could order the hatch ahead of time.
Jan 6, 2010
1,520
Chris,
I added opening ports in the head & over the hanging locker & this helped alot for cross ventilation. I removed my door & added the motel style type thick shower curtain. With the opening port & shower curtain people especially women, don't get as queasy while under sail or feel as claustrophobic. I gave my door away free to a fellow sailor.
The biggest 2 mistakes Frank Butler made were, two-part portal frames that were non-opening ports. Here in the Florida heat, it can be a cooker down below.
Every older Catalina owner has complaints about leaks/opening ports at one time or another. Check past threads on SBO Catalina port questions. My friend's 1984 Newport 30 has the same ports & deals with leaks also.
I'm dealing with 3 leaking ports now. This will be the third re-bed. But this time, I will try butyl tape instead of caulk.
CR
