I noticed some water in the aft cabin of my Hunter 376 yesterday. The mixing elbow on the engine runs against the inside of the aft engine access panel. The hose took the hardest part of this rubbing and developed a small hole which water was trickling out of.
I will replace the hose obviously.
Is that tight clearance normal? It seems like if the mixing elbow was turned slightly to the side then it would be better. Should I try to do that?
Picture included.
Picture included.
