Here is the problem: I can't get the mixing elbow out of the engine room!1. The mixing elbow is attached at the engine end with an ell which is held on with four bolts. The ell can be detached from the engine with no problem.2. The mixing elbow is attahced at the outlet end with the exhaust hose that goes to a waterlift muffler. This I cannont disconnect.3. The cooling water hose has been disconnected from the mixing elbow (open end can be seen in the picture.)4. Options:A. Remove the Mixing elbow/90-degree ell connector: Inspite of assembling this "loose" so it would be able to come apart easier next time it is STUCK! as in FROZE. Anyone who has ever worked on one of these knows the issue. Have not used any solvents like Knock-er-Loose yet but based on past experience I don't know if this would work anyhow. Besides, one could only use it on the lower part of the threaded coupling.B. Pull mixing elbow and 90-degree ell out through the aft end of the engine. I currently have the 90-degree ell disconnected from the back of the engine. Problem: there is not enough flex in the wire reinforced exhaust hose, and, the throttle cable is in the way. The cable could be removed but then there is still the hose flex issue. Also, the mixing elbow Plus the coupler Plus the ell is too large to fig through the remaining space.C. Remove exhaust hose from mixing elbow: This is what I'd really like to do and it would cure all my problems. The hose will absolutly not come off the end of the mixing elbow. I've tried wedging a flat screwdriver down between the iron elbow and the hose but I can't reach all the way around the hose so some of it is probably "welded" to the elbow - my guess. Question: is there something that one could squirt between the hose and the iron? Like, say, that stuff that electricans use to run wires through long conduits? Break fluid? Liquid dish washing detergent???D. The hose is in good shape so I really don't want to cut it - but that IS becoming an option.For the record, I've done this same project numerous times but NEVER had this much difficulty! And, the current mixing elbow and coupling were brand new the last time.What would a professional mechanic do?What would an amature mechanic do (besides take it to a professional)?Open to any suggestions!
