My new to me O'Day 322 has a Yanmar 2GM20F aux.
While bringing her home late last season across Lake Michigan, the engine alarm went off after motoring for about 1/2 hour in rough seas.
I throttled back some, and while considering options to return back to harbor, the alarm stopped, and I was able to motor at a lower RPM for several hours. Once in port, I found the antifreeze to be very low. I filled it with water, and motored 10 hours the next day at full RPM. I drained the water and filled it with fresh antifreeze at haul out.
While checking on the boat recently (on the hard, not run since I filled up the antifreeze), I found the antifreeze level down again.
Nothing in the bilge, and can't see any leaks.
What should I be checking? Seems odd that the level would be down, with no antifreeze in the bilge and the engine has not been fired up.
Greg
Greg
