P
Paul Cossman
I have a 1991 Hunter P42 with a Yanmar 4JH2TE (62 HP turbo) that has about 3200 hours on it. I am getting ready to cruise the South Pacific, and am performing routine maintainance on the engine in preparation for that trip (replacing mixing elbow, testing heat exchanger,rebuilding turbocharger, etc.).I have a transmission fluid leak that appears to be coming from the rear transmission seal. It only leaks about 3 or 4 drops per hour, not even enough to cause me to top off the transmission fluid level after the last 100 hours of engine running time. Should I be concerned enough about it to replace that rear seal? Or should I just put up with the minor leak?
