Number 1: minor leak from the strainer on the low-pressure side of our potable water pump:
What I don't know is: should the clear cover on the strainer have an o-ring or gasket? Because it doesn't now. I could try some teflon tape, but I can't find any kind of gasket on the Jabsco website. It's a slow drip from the screw on cover.
but it did finally fail .............. just not on the glued joint. Cut the material at exactly 90
