Here are a few of my criteria
I'm thinking about a bluewater boat myself and have started my research. I started out with the usual criteria: price, length, draft, hull type, rig, sailplan etc. After a while, I began to realize that a bluewater boat is a place where you spend LONG periods of time a long way away from assistance in all kinds of weather, often with little or no company. I concluded that a good bluewater boat must be safe, secure and comfortable.I believe strongly in the KISS principle but I don't think one should skimp on the essentials. As a result, here are some of the most basic things I'd want to know if I were actively shopping:1) Is there enough headroom to stand upright while cooking or taking off wet foul-weather gear? Some say that if you really want to stand upright, then you should go on deck, but sometimes that's just not possible...2) Is the boat reasonably fast? The difference between 5 kt and 6 kt doesn't seem like much until you realize that's a difference of 24 miles a day or almost 4 days on a 3000-mile transatlantic passage. Think of the savings in food and water and the reduced risk of being overtaken by heavy weather.3) Does she have good motion under way? Does she track well? Can she be sailed by a shorthanded or singlehanded crew or by a novice guest?4) Is she easy to maintain? Do I have to spend a lot of time varnishing? Can I get at the stuffing box if the packing starts to leak? Can I get at the engine if it dies at a critical moment (like coming in a rough, narrow channel and sediment in the fuel blocks the fuel filters).5) Is the boat well-ventilated below decks, not only at anchor in the tropics, but also under way and especially when buttoned up for rain or heavy weather?6) Is the boat reasonably dry (on deck and belowdecks) when under way?7) Once prepared for rough weather, can the boat take care of her crew? Can they rest comfortable below while waiting out a blow, or do they have to be up on deck working actively to keep the boat out of trouble?8) Will the cockpit drain quickly if pooped by a breaking wave? Is there a bridgedeck to prevent water in the cockpit from flooding the boat?I think people seek out good old boats like Allieds, Cape Dories and Contessas not because modern production boats are bad but rather because they're not as affordable. Just my two cents...PeterH23 "Raven"
