Min draft & type keel 1978 25' oday
E
Evans Spence
What type of keel fo the 25' oday's have I have a 1980, 1979, and 1978, all sitting in river. Need min draft for all also. Thanks everybody - anybody *o
Trevor - SailboatOwners.com
Oday 25 specs
Hi Evans - Depending on whether your Oday 25s have a Centerboard or Keel, I have the following specs (also, see Related link): Centerboard: 2' 3" up, 6' 0" down Keel: 4'6" I would be surprised if there were differences between the years you listed. Hope this helps, Trevor
Paul Mieszczenski
3' with the rudder
Evens, Trevor is correct with his keel dimensinons, but the C/B version draws 3' with the rudder attached. PM
G
Geof
Round up for Comfort
We have a '76 25 C/B and we won't take her anywhere thinner than 4 feet, and that's under duress. A small wake from a passing boat may cause the boat to bob up and down 3 to 4 inches. Then you get the trough and then you hit the bottom. So, 4 feet of water, board up, 10 inch wake from inconsiderate passing stinkpotter and you are looking at 3 feet 2 inches in trough with 4 inch bob and the rudder is suddenly supporting the boat. I know my math isn't exact, or neccesarily scientific, but the wake from a passing stinkpot can never be underestimated. There is nothing more upsetting than that shivering feeling the boat and you get when it is abruptly dropped on a hard object. Gudgeons are designed to hang rudders on, not boats. So, even though the specs might say 2 feet 3, board up and 6 down, I hate to leave it anywhere where there will be less than 4 feet, even at moon tides. Geof
