You know that might do. The total height now on a 100 inch trailer wheel base is 3ft(bed height) + 3.5"(wood) + 6'6" cabin height. On top of that the mast will be placed sloping forward, height unknown.This may be a bit late but could you ask the person transporting your boat to place it on 8"x8" wood timbers rather than 4"x4"? That would make a big difference as you would be able to slide a deeper structural steel member under the boat. If it's not too late, you could use your already fabricated tubes in the vertically stacked position rather than side by side.
So I would be concerned with the top heavy height of the load on cornering, and the overhead clearance with mast, but yeah it would increase the capacity of the beams substantially, although it's true the weight is located lower down on the keel. I'll see if that could be done.
What would you guys think about my changing the spans as indicated in this drawing. I have the option to have loaded at the same time the trailer the boat is sitting on. I would remove the undercarriage just leaving the frame. I didn't mention it because the wheels are splayed a bit due to the weight(bad decision by someone) and it's used just for yard moving at the marina. I was just going to leave it there, but I could use it to effect the moments to our advantage if possible. The height increase is another 3inches for frame.
Note also I think the 126inches for total span is more accurate than the 140 in the original drawing, since now I know the wheel span of the hauler's trailer.
Thanks for all the help guys.
