here it is, came today after months of waiting for them to become available. i was hoping (but doubted) to be able to just mount it and attach the wires after removing the old BPZ500 charge controller that is causing a RF noise on my VHF radio (see earlier post).
I have two solar panels, in series, and two 12 volt batteries, in parallel.
What i am showing are pictures of the fuse box that I already have installed between the PV input and the old flawed charge controller, and also the Battery out fuse box between the charge controller and the battery, near the battery. would this be sufficient?
And then the wiring diagram, which has a bunch of other things like ground fault protector IN SERIES with the PV input breaker, and a breaker in series with the battery plus wire. Two breakers in series between the solar panels and the charge controller?
Is all that really necessary? HELP!
Keith
Keith
