Mid ship cleats
Feb 16, 2015
36
hi I am planning on installing mid ship cleats bolted on my fibreglass toe rail as I can't get track cleats in Australia from Catalina direct and I do not think the track cleats we'll hold up as a double springs in a perment slip in 40 knots . Has any one done this ? Some people say the is stainless in the fibreglass ? The other thing is the glass thick enough to support this with a backing plate ?
Any idlers would be great I have a Catalina 310 number 42
Cheers mat
Matt, I believe the toe rail would be difficult to enable a good backing plate to be installed below, simply because of the way the fiberglass toe rail and hull to deck joint is built, if it's anything like my boat.
What our skippers have done is to mount their midships cleats on a support of wood just inside the toe rail to raise them up and then bolt through to a much more accessible place below the deck.
Single Handing 101.1 Midship Cleats Pictures http://c34.org/bbs/index.php/topic,4921.0.html
Good luck.
Oct 3, 2011
835
I love the fold down cleat, what a great idea and you do not trip over it and do the over the lifeline belly flop or fall on deck moaning!
May 8, 2011
189
ODay 25 Cambridge
I used Schaffer track cleats with a 1/4 inch pin on my Irwin 41 (25000 lbs displacement). I was a live aboard on the Chesapeake Bay and cruised the U.S. east coast and Bahamas. The cleats worked well. When in an exposed slip with heavy wind I would run additional spring lines to the bow and stern cleats. Mid ship cleats are great for getting into or out of a slip. I would go with 4 bolt cleats for add ons.
Nov 16, 2012
1,055
Cheers mat
Mat, you can also get the cleats from Garhauer: http://garhauermarine.com/catalog_process.cfm?cid=78
I assume they've got a distributor down there.
frosty
Sep 25, 2009
2
Catalina 310 Pittwater
I use the track cleats in my 310 located in Australia from Catalina direct. Work well and no problems with supply
