Microwave
Jun 13, 2016
21
Hunter 38 Mystic, CT
Need to replace microwave.
Can't find how to remove microwave from 2006 Hunter 38.
Does anyone know how it is anchored in?
Apr 11, 2010
998
Hunter 38 Whitehall MI
I've looked at my 2008 38 to figure out how it's in there. Had the same idea that someday I'd need to replace it and wanted to understand how.
I think the wood trim panel that surrounds the front of the microwave is held in my clips from the back. They are the same spring loaded clips that are used on the trim boxes that encase the bilge pump discharge, the head sump discharge, etc.
I think if you carefully pull on the panel (do it evenly so you don't break the panel) it will come off. When it's off you'll have access to the sides and bottom of the microwave. I suspect you'll sass how it's held in place.
May 24, 2004
7,237
CC 30 South Florida
I have seen no evidence that Hunter's designers provided a way for cabinets and panels to be disassembled to facilitate maintenance and service of components. If they had they would be advertising the feature. Boat interiors construction is very much like RVs and mobile home constructions where they use a lot of staples and glue to hold and give strength to light weight panels. Most jobs require some carpentry skills.
Jun 11, 2011
1,243
Hunter 41 Lewes
on the 41 the microwave wooden trim face just pulls off. It has clips that are sold here on SBO. Then the microwave is wedged in by two wooden wedges that you drive in opposite directions. You'll understand as soon as you take the trim off.
Apr 11, 2010
998
That is the way it is on the 38 too. There are several panels around the boat that snap in the same way. I've generally found that they did build things in ways they can be be disassembled. It sometimes just takes a bit to figure out how.
Oct 29, 2005
2,366
On my H326, the microwave is held in as how quadrille and uncledom had described. Just has to be careful prying out the framing panel.
Oct 19, 2006
337
Hunter 27-3 Brownsville, VT/Mystic, CT
I replaced the micro on my 2005 H27 this summer. I unscrewed the cooktop to get at it... then found I could have popped off the front frame as quadrille describes! I still would have had to remove the cooktop to get at a piece of wood going across the top of the micro and screwed in on either side to secure it in place. Ditto for reinstallation. Just removing the front would not have worked.
My OEM micro was 0.5 cubic ft, 500 watt. You can't find that kind of unit anymore, which is just as well because it was too underpowered. The smallest 0.7 cubic ft, 700w model I found could fit, except for needing about 3/8" extra room on the top of the opening. I was really hoping to find a 1000w unit, but they were all too big.
It's all happily in place now.
21
Thanks to all.
The front was attached with spring clips from behind. With a bit of even pressure it snapped right off.
Agree with VT Fitz, OEM was under powered.
Now looking for a replacement.
Likes: All U Get
