microwave on hunter 23
Sep 7, 2011
116
Hunter H23 Southwind YC, Milford, Kansas
Could not find this topic on a forum search so will ask it here. Does anyone have a microwave installed on their Hunter 23? If so can you post a picture or just explain where you placed it on the boat?
thanks
Sep 7, 2011
116
I have all of that. Just want some wisdom regarding where to put it. Thinking about under the aft end of galley and removing both cushions. Open to other ideas.
-na -NA Anywhere USA
Suggest a shore powersystem with an outlet
near where you want to use it. I suggested a small unit which can be stored away vs a permanent one as it will take space away and might interfere if ever selling the boat. Further you would not want it near the floor in the event water leak should cause lower areas of boat to be flooded getting into the microwave
Take a photo where you thinking of putting it so I can see
