Hi, sorry not a boat owner but I had a question I figured you guys would have ran into this the most...I have been getting mixed answers from plumbers.
Will metric pex work with imperial fittings? I think I'll be using press fittings, but it'd be nice to know for other fittings as well....same question for both pex-al-pex and oxygen barrier if that makes a difference...I can get metric tubing for really cheap and just want to use it for under floor, then mate it with imperial tubing above floor.
Would some sizes work but not others? It also seems MM pex uses the OD for the nominal size, and imperial uses the ID for nominal size(or close it it), is that correct?
