The one with the mallet was correct .......
Moisture meters only measure the 'surface moisture' in a laminate. Moisture meters are rarely 'calibrated'. That surveyor with a mallet was looking for delamination and in a cored structure also underlying rot. Such a procedure is looking for already developed destruction. All fiberglass is water permeable to some degree so a high moisture reading may be 'normal' water absorbtion. A high moisture reading from a meter only means surface moisture .... but 'may' indicate inappropriate water absorbtion due to hydrolysis or other ongoing 'destruction' that is deeper inside the laminate. A well made laminate structure of the proper proportions of resin and glass, etc. etc. that doesnt have 'discontinuities' may be totally saturated with water with no ill effect. I'd trust the guy with the mallet long before I'd trust a 'moisture meter'. A moisture meter can only be a 'corelation' to the laminate condition; otherwise, the ONLY way to know is to perform a destructive 'core sample' (then send to a laboratory, etc.) in those areas of suspicion. That said, a zone of high mosisture near a stancheon or shroud on the deck or other hardware probably indicates that the core underneath the laminate is rotting, etc.
