Returned from a very pleasant, relaxing sail on the upper Chesapeake a few hours ago. Got into the slip, secured all lines, and relaxed. Went below and let the engine idle to cool down about five minutes. My crewmate trottled up to shut off the engine, and said "hey, look at this." I looked up to the cockpit and he throttled up again, and no increase in RPMs.
Opened the engine compartment to check the linkage. It was fine at the engine. Pushed the engine throttle lever and was only able get a few more RPMs before the lever felt as if it hit a "stop."
Figured that the linkage had come loose at the pedestal lever and the "fugitive end" of the cable was just hitting something.
I just Googled Merrimen pedestals and was surprised at the number of horror stories regarding Merrimen pedestals.
Other than R/R the compass several years ago and looking down the pedestal, and doing some lubing, I have never thought much about it.
Didn't have time to work on it then but will do so next weekend. Will take down long handled needle nose pliars, surgical clamp, and some other tools to attempt a dianosis/fix.
Question - has anyone experienced this precise problem and what is the worst/best case scenario?
On the bright side, Murphey's attention must have elsewhere at that moment, cause we got into the slip just fine.
