A while back, I had a problem with getting oil into the lower unit of my 2000 3.5 HP Mercury Outboard. That was solved by a simple clean out of gunk in the upper fill screw.
But now I have water in the oil of the lower unit. The oil was milky white when I drained it out just recently. And a very noticeable lack of oil drained out. About 4 ounces, I'm guessing.
I never saw oil in the water around the outboard this season. But I did loose oil.
The only issue I did have was once I noticed no water was coming from the outlet hose connected to the impeller housing. But that was fixed by cleaning out the vent holes in the housing that were clogged with mud. Ran perfect after that.
As far as water in the oil, all screws (4) are tight holding the lower unit and prop seal on.
Anyone else experience this and how did you fix it?
Thank you for the help.
