Merc Bigfoot 9.9 Smoking
Darren Mayes
On our last trip out about 2.0 hours under motor the engine began to give off a little smoke. This is the first time that I have noticed it and perofmrance does not seem to have changed. The motor is almost 1 year old with only 25-30 hours on it. Oil level and condition is good. Any thoughts / suggestions?
Bill O'Donovan
A little smoke is okay
You don't say the size of the boat or the type of engine, but if it's diesel then a little smoke is to be expected -- indeed encouraged.
Darrel
Smoking Outboard
If your Merc O/B is a 2 cycle, smoke from the engine may indicate that the oil/gas mixyure is to rich. Check and make sure that you mix the oil/gas correctly to manufactures recommendation. To much oil will foul the spark plug and cause the engine to eventually stall. Another point, it is always a good idea to run the carburator dry before storing the motor, this will help keep from fouling the card jets and bowl. Fouled carbs do not run well.
Darren Mayes
Details
It is gas 4 cycle and is not "stored" I sail year 'round.
