Memorial Day weekend sail with family
shnool
Aug 10, 2012
556
WD Schock Wavelength 24 Wallenpaupack
Well you got THAT out of the way (they say everyone has to do it, 2 types of sailors, those who have run aground and those who will)... I've been VERY lucky and haven't done it yet, but my days are numbered I am sure.
Couple positive things.. you didn't over react... you recognized the problem right away, and corrected it. Nobody got out of sorts. Remember this last one now... the Capri 22 is a tough little boat, designed to be trailered, and is likely just fine.
The downsides... You COULD have some issues now. You obviously didn't hit sand/mud, but instead hit rock. You came to a dead stop at probably 3.5 knots with as much as 3500lbs boat and crew, so that's a lot of force to apply to 6? keel bolts, and some glass/epoxy. Keel bolts SHOULD be checked. The keel attachment point should be checked (for cracks in glass, etc). Watch the boat like a hawk for leaks esp around keel bolts. Now breathe and read that last line of the last paragraph again.
Simplest rule I can give you to prevent it in the future, because I bet several others knew before it happened as well while watching. "Red on your right, returning." You were leaving, so RED on your left, LEAVING. I am sure you know this, but I generally remind myself just by saying it. I am totally envious of your sailing venue too :)
Other simple hints... structures (points, islands, hills etc) have tendency to continue underwater. There was a rock jeddy coming out just about where you hit. My bet is it continues well into, and under water.
Last thing... HEY I WANTED TO SEE SAILS IN A SAILING VIDEO!!! Glad you got the whole family going out too!
Slartibartfass
Capri 22 Mod
Dec 13, 2015
499
Catalina Capri 22 1139 Mamaroneck, NY
Thank god I was going very slow. Maybe a knot. So far no leaks. Boat is still pointing nicely. I will use my GoPro underwater to check out the keel.
shnool
Aug 10, 2012
556
brilliant, and that will work! Probably not a scratch, like I said, these are TOUGH boats.
