measuring height
6,990
Look around the room
is there anything that you can use as a crude lathe? You cut down a bunch of trees and turn their trunks into measuring devices. then take them to lowes and buy the right ladder.
Ross
Jun 15, 2004
14,693
I have a good turning lathe. i could cut a tree and bore holes through it at 12 inch intervals and then split it perpendiculat to the holes and put in rungs to make a ladder and see if it was long enough. If it wasn't I could cut a taller tree and try again. There is always a way.
Ross
Jun 15, 2004
14,693
I have some string may i borrow a balloon?
caguy
Sep 22, 2006
4,004
Turn all of the lights off except one. Then measure the shadow of a yard stick. Then its just a simple proportionality.
Feb 10, 2004
4,235
Hunter 40.5 Warwick, RI
Ross,
It's a good thing that we all don't charge for consulting or you would have a $1000 bill for sure. There sure has been a lot of thinking on this project.
I especially like Frank's (caguy) suggestion of the yardstick and shadow length. No thinking inside the box for him.....
Ross
Jun 15, 2004
14,693
I am surprized that no one suggested checking the wattage of the light and then measuring the luminus intensity at the floor and calculating the distance based on the inverse cube of the intensity versus the distance.
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
I see a joke coming on:
"How many sailors does it take to measure the height of a light fixture?"
Ross
Jun 15, 2004
14,693
Just one with 47 advisors shouting instructions. ;)
Now for the next question what is the best and/or safest why to change the light bulb?
Feb 10, 2004
4,235
This is an easy one. Hire someone else to do it and don't stand under the ladder.
