Meant to include this link.
Oct 30, 2019
119
http://www.albinvega.co.uk/windows.phpNicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
Sent: Friday, March 05, 2010 1:03 PM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Re: Window Seals
4 mm is correct. There is an alternative to using the original rubber seal system, in the form of a new extruded aluminum frame and 5mm glass.
I did the job using rubber last spring. Use lots of soapy water and lots of silicone spray!
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
Sent: Friday, March 05, 2010 12:35 PM
Subject: [AlbinVega] Re: Window Seals
Adrian,
I believe the glass is 4mm thick. If I recall correctly, this info came via Steve Birch.
Good luck with your project .. keep us posted on progress!
Peter
#1331 'Sin Tacha'
