Meant to Be- Now up on the hard
My 1979 Hunter 30 is now up on the hard on Maryland's Eastern Shore.
I have now used the same covering system for the third season. This will work for any boat with a toe rail with perforations similiar to my boat.
The wire channel lock and the zig-zag wire are used in the greenhouse industry, as is the covering which is a clear greenhouse film and good for four to six years, if you remove with care. I have marked the channel on the reverse with port and starboard and place from the bow (#1 #2#3#4 port). The channel and wire cost was about $75.00 and is available from Greenhouse supply companies. The film is more money depending on size and number of rated years. The film is available in clear or white and has UV inhibitiors. I have used the clear 4 year rated.
I have enclosed some pictures. The film stays on the boat and does not shred like the tarps I have used in the past.
Send me an e if you have any question.
Ian McGain
Meant to Be
Ian McGain
Meant to Be
