MD6A: blocked water hole on exhast manifold
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi all.
I'm having engine overheating problems - due mainly I expect to
blockage in exhaust manifold.
I'm planning to clean out manifold but I first removed thermostat
housing and found thermostat missing - so far so good, should help
water flow.
But the small circular hole on the lower edge of the exhaust manifold
is blanked out with some grey metal. The blocked hole mates with a
corresponding water hole on lower edge of thermostat housing (this
hole is not blocked) - there is an O-ring to seal the union.
[See Paragraph 49 with photo on P22 of MD6A/MD7A Workshop manual.]
Surely this water hole on manifold should be open to allow water flow??
Should I drill it out?
Thanks for any advice,
John
Vega 1447 Breakaway
Dec 11, 2007
179
- - port st. lucie,fl.
-John-
The blocked hole you are referring to is a bypass provided for a
water passage when starting up and the thermostat is still closed.
With the thermostat removed, it would not be required. However in
view of your heating problems, it certainly could be useful.
Richard, V1812
-- In AlbinVega@yahoogroups.com, "John" John.Kinsella@... wrote:
Nov 8, 2001
1,818
Hi John
Leave well alone, they are all the same, domnt drill it out, just clean
the water channels.
Cheers
Steve Birch (Technical)
