Roy, thanks for the tips. But can you tell me about the washers that
need to be "replaced" ? How many are there under each injector? After
you remove the injectors, how do you get those washers out? Thanks
again, Trevor #2915
________________________________
AlbinVega@yahoogroups.com [mailto:
AlbinVega@yahoogroups.com] On
Behalf Of groundhog
Sent: October 19, 2007 5:18 PM
To:
Subject: RE: [AlbinVega] MD6 Injector Removal
Trevor,
I believe there is a sketch I put in my picture file under "Good Things"
with the injector dimensions. Has some other info on it too.
The injectors just slide in there. There is no threads or anything.
I remember having trouble getting them out too, but can't remember how I
got them out. Think I just kept pulling on them and they came out. Maybe
open the decompression lever. Maybe warm up the engine first.
Try a big screw driver under the 3 washers.
You will need to change out all of those little metal washers as they
are meant for a one-time deformation.
If you intend to check compression, there is a manufacturer/partno. on
the sketch that makes an adapter.
Roy
#1813
