Hi all.Desperately need help with gearbox.Here is the problem.After a long trip during which all ran fine upon return to slip forward would not disengage.It would go into neutral but it stayed in forward.I disconnected the linkage and tried shifting by hand while engine running.First time it took a few minutes for shaft to start spinning but it did.Going into neutral it stayed in forward.Shut the engine and restarted it to try with reverse first.Same thing.Shaft started to spin slow but built up speed in idle.Than it just slowed to a stop and no matter how much I moved linkage back and forth shaft would not move.It seems to engage in forward but shaft will not move.Same in reverse.It would creep but not spin.When I went to change oil gear case oil was to the top before change.I tried all this after I put new oil in engine and gear case.By the way I found gear case oil to be full to the top. Any insights would be greatly appreciated.
Regards
Branko
Regards
Branko
