Well, I don't know if there is such a word as "under heating" but my MD11c will not budge the temp needle. New gauges were installed 3 years ago and the engine has run cool ever since, usually 120-130 range. (It was not my boat prior so I don't know what it did before.) However at that temp the reading is not clear; not sure what the running temp really is but it's less than 170. The mechanic who put the gauges in said he had checked the thermostat and didn't know why it was running cool.
This year the needle doesn't budge. I assumed the gauge was not working until I forgot to open the cooling inlet seacock. When the exhaust sound changed (no water in the muffler) I realized the problem. The temp was 160. Bu the time first mate got below and opened the seacock it was 180. Then it came back to the 120-130 range. Engine seems to run fine. It hasn't been run since.
I'm guessing the thermostat has been defective with partial opening (leaking?) all along and this year it just stuck open. Before I dig into the bowels of the engine compartment (or pay big bucks to have someone else do it) are there any other ideas I should pursue?
The boat is in, and has been for 20 years, fresh water.
Geoff
Geoff
