Maybe a Miracle in the Making
3,562
Endeavour 32 Portland, Maine
First, let me say that I am deeply touched by the responses to my last post. Thank you all for your concern and your comments about your enjoyment of my writing.
It’s easy to make the decision to write about today’s medical events since they directly bear on my cruising. The PT who assessed me today is a way ahead of any of the several that I’ve had in Maine. He listened to the history carefully and went at the problem just the way Gary at Drum Point Marine did my oil leak. He came up with equally positive news and we are now both confident that he can get me back to where I was a month ago.
I’ve moved into my friend’s house for a while to get away from the motion of the boat and the need to climb over the lifelines to the dock (one of those very short fingers with piling slips where you have to go over the bow.) I’m going to go to PT three times a week until I’m ready to resume my cruising.
The medical scoop for those of you who are interested: (Here’s a good link for orientation:
http://www.mullumbimbychiropractic.com.au/common-problems/the-sacroiliac-joint)
The PT is positive that my problem is not due to worsening of the arthritis. It doesn’t happen that fast and the fact that I have been through a few rapid cycles of getting worse, better, and worse tells him that this is being caused by muscles. If it were the arthritis in the joint, it would have been a slow and inexorable progression.
He then did a lot of checking and examination and concluded that my Ilium (the big hip bone) is rotated forward, twisted around the sacroiliac joint. The ball and socket is slightly too far aft and the big knob of bone under where most people put their cell phone on their belt is too far forward.
As Stephen the chiropractor said in the last thread, this kind of misalignment is common and a cause of SJ inflammation and pain in many people. When it’s happening to a joint already compromised with arthritis, the result is very severe pain. Going in this morning, it was so crippling I could barely walk.
The arthritis was diagnosed by X-ray 10-12 years ago when I became nearly this crippled after hand digging several cubic feet of dirt mixed with rocks that the shovel kept hitting, putting shock loads on my whole spine. That was back when I thought I was still young and was certainly still stupid. I just kept digging through the pain thinking how strong I must be getting.
My doctor at that time, a D.O. who specialized in manipulation, put me in a sort of fetal position and put nearly her full weight on me (that was exciting). There was a pop and immediate relief of 80% of the problem. PT took care of another 10% and I’ve been dealing with the remainder pretty well ever since.
I mentioned that to the PT today and he said, “Yes, and I could do that. So could a chiropractor However, your hip is being pulled out of position by muscle tension which means that some of those muscles are strained close to capacity. Stretching them further and moving everything around forcefully may work . We have some time here. I’d prefer to first try getting everything relaxed and retraining your muscles to position the hip properly.”
He also pointed out that I have a lot of muscle development from my healthy cruising life. I mimicked some of the anchor hauling and other things I do and, wow, did it hurt. All of the muscles that do these tasks are pulling in the same direction the hip is rotated. Direct manipulation is therefore working against stronger forces than in many people who have this problem simply because the muscles have gotten weak are not supporting the bones properly.
My original diagnosis was Piriformis Syndrome, my doctor’s theory being that the inflammation from the arthritis was stimulating the nerves nearby causing the big muscle in the hip to clamp down on the Sciatic nerve. I’m not sure now that she was right. The symptoms and treatment are similar and, after having all this explained to me with the full size skeletal models, I think I may have had this hip rotation to a lesser degree for years. She undid most of it but I was in some pain for weeks after and walking and moving so as to protect the SI joint also promote shortening of the muscles and rotation of the hip. No one before ever did the careful measurements of exactly how the Illium was positioned.
I might also have just pulled the Illium out of position with all the recent excess activity combined with additional muscle tension produced my mental stress and worry. It doesn’t really matter, the objective now is to get the hip back in position and teaching my body how to keep it there. At some point, it might need the additional help of direct manipulation of the bones but doing that after the muscles are more with the program makes good sense to me.
So, once again I’m wrong. Good thing I’m used to it. My second “Titanic” show ends with me saying in the last scene “Gee, I was completely wrong.” Great TV. I was wrong about the oil seal and, boy, am I ever glad. Now, I find that I had it backwards on this hip thing. Instead of arthritis hurting muscles, it’s muscles hurting arthritis and you can teach muscles how to do almost anything. I tell you, being right isn’t all it’s cracked up to be.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Good four you Roger. I was saving a botttle of 18 YO singel malt schotsh for you're sailing retern. Welp, your haf is gone.
All I Had
Nov 6, 2006
10,121
Ahh the tunnel light moves one step closer.. Sounds like you found a good guy..
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Roger it sounds like we have the same hip/back problem. In my case I have been managing it with a combination of stretching (PT taught), Orthopedic support in my shoes (I can't walk a block without them), and a chiropractor for hip realignment. (For when I can't get it back in place with the stretches and a pool noodle.)
I walk about 6 miles and go up and down 2832 stairs 5 days a week. I try and get this done before 1 pm. Then I am off to my contracting job. (I'm the boss and try to just point and give orders but still have to get physical.) I avoid using a shovel or crawling around on someones roof. These things have me going to the chiropractor at about 9 am, just before my daily hike.
You will heal. Just do the exercises the PT gives you and you won't be in as much pain. I only visit the chiropractor once every 2-3 weeks now. Its not fun if you can't straiten up and your hips are out of line.
(No I didn't count the stairs, the post office did.)
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Roger,
What a week you've had! Rest up (except for the pt) and recover. You've earned it. The ICW will be there when you're healthy and rejuvenated.
Chris
Dec 8, 2006
1,085
Oday 26 Starr, SC
Stephen's comments
Roger,
So Stephen's opinions from afar were close? We all need to recognize his positive contribution. Hip Hip Hurray for Stephen.
His third comment should be reviewed: "The third and last necessary ingredient to cure these problems is, as with all injuries, the protection of the weakened area until it is strong again, and long term protection from unreasonable loads."
Here is topic for you to discuss with your professional medical persons:
Back support.
This topic can be discussed from two separate concepts.
First, if you go to a sports gym or facility, weight lifters wear a back support belt. Discuss reasons for wearing.
Second, is to maintaim muscle warmth. The modern light elastic back supports keep the underlying muscles warm. This warmth helps the muscles take new work or heal.
See these examples, but understand there are many:
http://www.mcdavidusa.com/store/item.asp?DEPARTMENT_ID=73&ITEM_ID=93
http://www.mcdavidusa.com/store/item.asp?ITEM_ID=95&DEPARTMENT_ID=200
I routinely use such light weight rubber belt when driving long distances. It has helped my back. This is just antidotal comment. I recommending discussion of topic for your consideration and evaluation.
Again let me repeat my comments from previous post. Do not rush recovery. As you get older, it takes longer to heal.
In meantime, write a book? Design the boat to handle the AICW? Sample Junior Johnson's remedy? Find a facility with heated pool? Take up painting, that is artistic painting? Howl at moon?
Warm zephyrs,
Ed K
134
Hunter 410 N. Weymouth, MA
Roger
I too have suffered from similar problems for a long time. have your PT check you for a leg length problem. turned out for me that my left leg is 5/8 inch longer than the right. anything over 1/2 inch or so is considered extreme. so at 63 this problem has developed for well over 40 years. I now wear a 3/8 inch heel support in my right shoe and after 9 months of PT and chiropractic help, things are pretty stable. I now can walk virtually pain free. I still do a daily routine of stretching etc. which I'm sure you will be doing, but what a difference. and keep the post coming. I, like many on this forum, have been living vicariously thru your posts. good luck.
May 24, 2004
7,190
CC 30 South Florida
I bet you did not think a few weeks ago that things were going to go this way. I was once told to fore-go worrying about what may happen because the great majority of the things we worry about never happen or happen in a different way. That is not to say that we should not plan for anticipated contingencies, as planning is taking positive action, but excessive worrying is useless and harmful. The best way to prevent it is to recognize it presence and re-direct the mind to another activity. We think of young people as being carefree but what they do is not engage in useless worrying. We need to re-learn that. I'm not into meditation or none of that crap but that advice stuck with me and I believe has served me well and just wanted to share with all.
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
So, does this prove that 2 wrongs really do equal a right? ;)
Ed's really right about warmth. After my injury I finally figured out how "those old guys" could always tell the weather and when it was gonna rain. :)
Nice post, Benny. I may have mentioned this before, but my Mom was always saying to "stop worrying about worrying."
Dec 28, 2009
397
Macgregor M25 trailer
Worry is like a rocking chair, it gives you something to do, but does not get you any where.
Roger, I've really enjoyed your posts and insight, take care of the body first don't rush it throw away the schedual.
Fred
Jun 6, 2006
6,990
My mom always says "live is what happens to you while you're making other plans"
Chkm8
Mar 20, 2012
4
Beneteau 411 or 400 Placencia, Belize
Worry
You guys are right on Warmth works wonders, so I moved where it is always warm! Worrying only gets you busy worrying more and getting nothing done
