Maxwell Winch manual/instructions
David
The previous owner of our boat installed a Maxwell Freedom 500 anchor windlass. Unfortunately we have no operating instructions for it, only the installation guidebook. Does anyone have operating instructions for one of these? Maxwell so far has been non-responsive. Thanks in advance David
23
- - Long Beach, CA
Maxwell Service Centers....
This link will take you to the North American Service Centers. They list phone numbers where you can probably get the answers you need. HTH... George
Jun 4, 2004
629
Sailboat - 48N x 89W
Up-Down
1. Turn windlass circuit "on". 2. Push or step on one button to lower anchor & lay out rode. 3. Secure chain in chain stopper. 4. Remove chain from stopper. 5. Push or step on the other button to retreive rode & raise anchor.
Tom S
David what type boat do you have?
I know on many Catalina's they only have an "up" switch typically a rubber foot switch you will see when you lift the anchor hatch on the bow. Most (if not all) Catalina's did not come with a down switch, thus to drop the anchor you need to stick a winch handle on the top of the Windlass (in the hex slot in the middle) and rotate counter clockwise. That will release the 'clutch' on the anchor rode and you "should" be able to free fall the anchor line. When you have the rode out where you want you can "tighten" back up on the 'clutch' by turning the winch handle clockwise. To raise the anchor press the rubber foot switch. FYI -- pretty easy to add a down switch so you don't need to mess with the winch handle and the clutch. Does this make any sense to you???
Mel Elliott
Maxwell
First thing I would do is go to Maxwellwinches.com and see if I couldn't download the manual from their website.
David
Thanks all
Thanks all, I have an up and down foot switch on the foredeck. The part I was missing was how to make it freefall. The power up and down is already figured out. The Maxwell site does not have manuals. David
