Never heard that one before!
Your theoretical hull speed is about 7.46knots +-. You can exceed this speed, but as explained before, you have to have enough power to get the boat up on the water, instead of in it. given the disp. of a sail boat that has lead(ballast)under it, it isn't easily put up there and its next to impossible to keep it there for very long. usually only a few seconds. at the end of a surf you will hear a definate differant noise of the water around the boat. sort of a "whoose" sound. then you will feel the boat settle back into the water. when this is all is happening you'll see the speedo surge to maybe 9knots or something greater hopefully, then slow back down to your hull speed of about 7.5 knots. you will also feel the boat sort of rise up when it starts to surf or plane. then just wait for the next gust and wave and do it all over again. btw its extremely difficult to get anything other than a sled to surf upwind. most typical boats that have a ballast to disp ratio of 40 to 50% can't surf upwind. the easiest way is downwind. on a beam reach its also very difficult but can be done, but no where near the same amount of surfing. on a reach when you get that much power in the sails you have a heeling problem to deal with.
