Maximum Motor Weight for '77 Oday 22
Jul 25, 2012
1
Oday 22 Sayville
I need a new motor for my 1977 O'day 22. I'm looking at a Tohatsu 5hp which weighs 58lbs. This seems heavy considering how thin the transom is. I don't know the weight on my current Evinrude 6hp 2-stroke, but I'd guess it's about 40lbs.
Does anyone know what the maximum weight is for a motor for this boat?
Dec 27, 2012
587
Precision Precision 28 St Augustine
I couldn't answer that but Im sure your fine. My 22 has a 6 HP 2 smoker. If I ever replace it it would be with a 6 HP 4 stroke.
Mar 20, 2012
3,983
the transom should be beefed up a bit no matter what the motor weighs....and the weight isnt usually the real problem, but its the thrust of the prop under adverse conditions in combination with the weight.
when i say adverse conditions, I mean at WOT when you are trying to push past hull speed, or driving into wind and wave action...
motors up to about 125 lbs (10hp 4cycle) have been mounted on the transoms, using a bracket and a good strong plywood backing inside the hull, but at that weight, its usually the undersized bracket that is the major concern.
personally, I like a backing plate on both the inner and outer side of the transom to better distribute the force over a larger area (stainless or aluminum outside), but i have seen some pretty light mountings without backing plates that have stood up to the abuse....
a 60lb 5hp motor wont be too much different than a 40lb 6hp.... as, while you are increasing the weight, you are at the same time decreasing the thrust/leverage applied while under engine power...
Jun 2, 2004
1,956
Oday Day Sailer Wareham, MA
How old is your current 6hp Evinrude??
The older model (1979 or older) weighed 55# (20" shaft), the 1984 and newer (not made from 1980-83) weighed just a bit more, 56# (15" short-shaft) or 59# (20" long-shaft).
Other owners have put up to a 9.9 hp (75# or more) on the 22, O'DAY "rated" the 22 for up to 15hp so the bracket and thus transom should be able to handle up to at least an 80# or heavier outboard if in good condition (no obvious cracking or excessive flexing).
I'd say that Tohatsu should work fine on the boat, and the weight shouldn't be a problem if you currently have a 6hp as you describe (that new OB might even end up weighing ever so slightly less than your current outboard).
mm2347
Oct 21, 2008
243
oday 222 niagara
I have a 1984 222. Had a Honda 9.9 so used it. It weights about 110 # . The 2nd season kept on a mooring I noticed a gap developing at the Mount to transom. Put a hatch in the star. fuel locker and installed/4" steel backing plate. The motor has been great it performance and starts 1 or pulls. But it is heavy and is overpowered for the boat. Someplace around 1/2 throttle is 6mph and full is only noisier but no faster. My first choice if starting from scratch would be about a 6 hp long shaft, small amp. charging ability and the lighter the better.
