Masthead question...
May 23, 2016
1,024
Catalina 22 #12502 BSC
Replacing halyard masthead sheaves to accommodate 8mm line, made the mistake of ordering from CD (they said fine w/8mm, not so by my eyes. Then read Stingy's post on replacing with Ronstan RF251 sheaves (on order now), simple enough. What's up with the aluminum plate atop the masthead (for windex, etc.), held in place with double faced tape! What have you guys done about that? Drilled & tapped it to the masthead? (not much meat there to drill & tap to)...
Thx in advance,
Ron
May 23, 2016
1,024
Gene...helpful....diy solutions are usually the best! Nice work...!
Beneteau 323 Annapolis MD
Now Gene, THAT's the kind of pics everyone should have about everything on their boat!
Likes: greg_m
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
You might reduce the amount of water coming down the mast if you replaced the sheave cover. I agree the double sided tape bothers me, too.
You might fabricate something that comes off and is held in place (in part) by the masthead light extension.
Then again, what's a little fresh water? (In our case, in the Chesapeake, the Starlings would be depositing other things into that slot :^))) )
May 23, 2016
1,024
SG, good point, some kind of "cover" would be desired for sure, whatever it is, needs to be fabricated...
Jun 18, 2015
69
Mascot 28 Pilothouse Motorsailer Grand Manan
A suggestion. Wrap your VHF socket,connector & coax completely with self amalgamating tape & then coat the tape with Liquid Tape. Both are available from most marine suppliers. / Len
Joe
Jun 1, 2004
8,007
None of the Catalina masthead fittings are covered... that was an owner addition. You can make brackets or covers with a U channel piece of aluminum and self tapping screws into an area that won't interfere with the sheaves.
The anchor light was standard equipment on that generation of catalinas 22, 25,27, 30 ...
Originally, the boats came with wire to rope halyards... the sheaves in the masthead had a max width of 1/4 " to allow for side by side mounting... so... if you convert to all rope halyards.. you must be aware of those width limitations. My solution was building "tapered" halyards.
Likes: Leeward Rail
Sep 14, 2014
1,253
Catalina 22 Pensacola, Florida
You can buy a rubber boot for the VHF plug (PL 259) into the bottom of the Metz stainless steel antenna at all RV stores, same size as used for cable tv or CBs.
