Masthead Light wiring
11
2 27 SF
There is an open between the DC panel and the masthead light. Does anyone know how the wires are routed?
Nov 12, 2010
12
Catalina 27 Seattle
Ever Figure Out the Wiring Layout?
I'm having a similar issue and it looks like the masthead light wires disappear between the headliner and the deck above the starboard under-cabin berth. I'm hoping that you found someplace closer to the mast where the wiring is exposed.
Feb 18, 2009
11
2 27 SF
We found an oval opening near the base of the column that supports the mast inside the cabin. The hole is on the side of the column that faces Starboard (under the forward seat of the dinette). The antenna wire was routed up through this opening. The task now is the fish the wire up through this opening into the mast above. the plan is to use fish tape or pull a lead wire up that is attache to the antenna wire. We are really hoping we don't have to step the mast.
