Only if You Want To...
...It becomes your choice if you want to. You may go up the mast and remove them, then go up, again, in the spring, to do the reverse procedure. Or you can pull the mast and do that more easily. Remember to tie off the cables. I always leave the stick and instruments on, except last year when I changed everything when it was down.
