Mast
Dec 7, 2014
78
Catalina 27 Alcova Boat Club
I was wondering if masts are ever spliced?
My mast on my 1977 Catalina Tall Rig broke at the spreaders (long story).
I have been unable to find a tall rig mast. I have found several standard masts.
Could I splice a section off the bottom of my broken mast to the standard mast.
I believe standard mast is 33' and tall rig is 34.5'.
Thanks
May 24, 2004
7,174
CC 30 South Florida
Yes they can be repaired with a sleeve or a plug and as a matter fact it will result in that point being stronger than the rest of the spar.
Dec 7, 2014
78
My thoughts are that I buy a Catalina 27 standard mast, cut a 1.5' section off of the bottom of my tall rig mast, construct a sleeve and join the two to make a tall rig mast.
I am thinking of making a sleeve from a 2 ft section of solid aluminum and machining it to fit inside the 2 mast sections.
I am skilled at ACAD and can make a file for a friends CNC machine. Have this sleeve machined, drill and tap the mast and sleeve and use machine screws to join the 2 sections.
Also being that the splice is only 1.5 feet off the cabin top I would think there is not much bending moment at this location.
Joe
Jun 1, 2004
8,199
If you do it that way, make sure the spreader location specs to the tall rig,, to deck and to masthead. My question to you is: Have you considered repairing your existing mast... fishing the two damaged sections together then employing an experienced welder to insure a good connection?
jrowan
Mar 5, 2011
1,294
If you are going to the trouble to buy another mast, then have one made that fits the length & specs that you need. You are going to go to a heck of a lot more trouble to buy another mast & then try to add a piece from your old mast? More work then you need to do, mate. My advice is contact a spar maker, such as Hall Spars or Charlestown Spars, & get it done right, the first time.
Dec 7, 2015
3
Catalina catalina22 edgartown
I am now a proud owner of a 1972 Catalina 22. Unfortunately, I need a used Mast to complete this classic sailboat. Any leads?
Apr 14, 2014
17
Catalina 30 Gulf of Mexico
jrowan could not be more right!!! i wish i had read his post before my mast project.
During their hay day Catalina must have used 20 different extruding machines / vendors to manufacture their mast and booms, you'll be incredibly lucky to find perfect matching mast for your add-on piece which should be installed on top of the mast.
The added length for a tall rig usually happens above the spreaders.
A solid sleeve is really a great product idea for a busted mast at the step or below the boom.
I do like your way of thinking.
We attached our add-on piece at the "top of the mast", very little load.
First, we found the best looking / fitting matching standard mast we could.
Second, built a T-bar w/ added shim that can be ground down (see attached pic) for adjusting that fit my slug track tight and perfect assuring a smooth hoist;
We then champ down both parts down using two 4" x 4 x 3/8" thick aluminum angle 3-4ft lg on both sides of the mast using hog jaws or 11R Vise grips assuring a perfect line; " do not use angle "iron", this could transfer carbon into your aluminum mast which may cause rust, it will rear its ugly head before, during and after painting.
Then Slide the t-bar and shim together back and forward as if it were the slide slug, " perfectly smooth transition, Very important !!".
Third, we purchased 3/16"x 6' long type 6061 T6 aluminum 3 or 4" flat bar as wide as will lay flat inside both port and starboard sides of the mast, these are the inside fish plates.
We then drill 2ea 1.25" weld plug holes; use a rose bud to preheat aluminum fish plates, bevel the weld joint 45 degrees out approx 1/4" each side and then made one large pass using 5183 filler rod, we then ground down the welds a bit to blend nicely. (see attached pic)
Be ready to compromise a little quality on your over finish product due to mismatching mast parts.
Once complete, painting your mast will disguise the splice quite well. Awlgrip all the way, one coat per primmer, two coats primmer and three coats paint , hard first sand 80, second sand 180 - 220 then lightly sand using red scotch bright brand and tack rag between all coats, we used flatterer in all last three coats; wanted to make the mast, boom and spreaders appear as old as the boat. Good luck on whatever you decide, ether way its a ton of work!
