Hi All,I have a mast-project going on right now on my Catalina 30 w/ a 40 ft mast and wanted to ask a few questions regarding the re-wiring aspect of the job:- What gauge mast wiring should I use? I have an anchor light, steaming light and 2 spreader lights.- How does the plastic-tie method of securing all wiring inside the mast to avoid slapping against the inside wall work? In case your not familiar - it includes securing 4 12' plastic ties around the wiring bundle every 3-4 in star-like pattern with the tails flairing out. The tension on the excess tail against both the mast wall and each other will supposevly hold everyting suspended. any pro/cons with this? Seems much easier than runing a conduit and drilling rivot holes. It does not interfer with that halyards either. I have the wiring mentioned above for lighting along with a wind-instrument data line and VHF cable.thanks - Rob
