Mast Wiring
G
Gerry Bogert
I have a wiring problem with the mast lights. I believe the problem is the connector at the bottom of the mast. Has anyone cut an access hole near the base of the mast to repair wiring? I would shape the hole with rounded corners and make a stainless cover plate. Information or pictures would be appreciated. Hoping not to have to remove and reinstall mast. Gerry Bogert Two Drifters
