Drumbeater's got it right...Don't mess around with auto wire, use marine grade as it is tinned and therefore MUCH more corrosion-resistant. 14-16 ga should suffice for the length of the mast run.
And, excellent advice, James, to use heat shrink (moisture seal as well as mechanical support of the connection), ...IF you should have to splice (avoid if possible) !
