Mast Wiring Replacement...
Dave Busby
I have an 86' 25.5, and I need to replace the mast wireing (two runs). The wire looks to be outdoor line cord (old). The mast is 30' tall, and the weight of the wire will be heavy on the connection at the mast-head, and the streaming light. Does anyone know how to strain relief the wire? Thanks.
Mark M Smith
Mast Wiring
Mast "wiring" is generally called rigging, just so you will know, anyway the people that made your rigging are located in Largo FL Seco South 2050 34th Way, Largo, FL 33771 (727) 536-1924 They will have the measurements but they will probably ask you to send your old rigging for measurement. As to how to releive the strain-- the best way is to drop the mast-its NOT that hard at all. I hope this helped.
Dave Busby
Thanks...but
The riging is the stays & shrouds. I'm talking about the ELECTRICAL wiring INSIDE the mast. And, by the way, SECO did not do the wiring (or riging) Kenyon Spars did. But thanks anyway.
