Hunter used a 10 connection terminal block screwed to a panel that is above a v-berth closet. To access it you need to remove and work through a small panel in the top of the closet. It sounds easy but it is a major pain to bend squirm and make connections in a dark space through panel barely big enough to stick my arms through. It is a perfect example of doing a job on a boat. I unscrewed the terminal block from the panel and pulled it through closet top panel so it is a little easier to work on but is still a pain if you ask me. Has anybody changed this set up maybe used bullet or pin connectors. I'm thinking plug connectors with maybe 4 connections per plug but not sure yet how big of plug would pass through the deck pipe opening. Any other ideas or upgrades folks have tried or dreamed of would be welcome.
