For the record, I mast raise IN the water ONLY because our launch ramp has trees all the way to the water (no room to raise a mast). Doing it on the trailer means a more stable platform while raising... it's safer.
YES YES YES... if you can get 3 people together, raising the mast is easy. Again, only use a gin pole or A-frame if you have to do it solo.
The weight of the stick is irrelevant, because the problem isn't the weight, it's the initial effort to move the mast. You can NEARLY lift the mast yourself once you've lifted the aft end with a crutch (this while standing near the mast base, where you need to be to get it all the way up)... but the problem is, OK once it's up, without someone else to put the pin in, you are kind of stuck.
