they are all about the same. Go to the link below to see an illustration of mast raising. I would practice in the driveway (with some assistance) a few times, before you try it for real and solo at the ramp.Also you can search the web for other mast raising illustrations and tooling.Regards,Ted
To be safe use a bridel on mast like the one on the gin pole,just to keep it from going side to side on you. I if it's a big stick like I have,I use the 12V trailer winch(two way type) for up and down power to make it one man EZ.
I noted a variant of that method recently that didn't require pivoting the A frame. It uses a fixed line from the bow stem to the apex of the A frame. Then has a sheave at the top of the A frame for a line that pulls the mast up from just beneath the spreaders (hauled and supported there by the main halyard). A trailer winch could be mounted on one of the A frame legs or the line routed back to sheet winch. Two advantages... the frame legs don't have to pivot so they can be anchored easier... and the apex of the A frame stays closer to the mast so there would be less tendancy for lateral movement prior to the shrouds firming up.Either way is reported to work well.
Try a "Google" search for "Macgregor mast raising" and you'll get a lot of hits. Here is one with a picture...http://www.macgregor26.com/mast_raising.htmI retrofitted my h260 with a very similar system that uses a single gin pole attached to the mast and use the main sheet tackle for the lifting lowering power. I always raise/lower the mast single handed.Fair winds,Tom
