Mast stepping/raising (H26.5)
Apr 3, 2020
191
Hunter 23.5 Frenchtown, MT
Hi all,
I've been doing some searching and not having much luck. The marina where we have a slip for this coming summer has a couple mast cranes, and I'm trying to figure out how to use one to help raise the mast on our 26.5. Mostly, how does one rig for lifting and then disconnect?
With Orbweaver (SJ21) I built a gin pole that works fantastic. The mast is controlled all the way up because the shrouds are attached almost inline with the mast hinge, so the mast can't move side to side while raising.
On the Serenade (the 26.5) the shrouds are not in line with the mast step hinge, so they won't provide any support until the mast is nearly vertical. I have thought about rigging a gin pole again, but then it's going to require some careful thought to supporting the mast during the raising process. SO, I'm curious what other's have done? Ideally I'll have 2 methods: one that can be done while on the trailer, and a second using the mast crane at the marina. I'm sure there will be folks around willing to help with the mast crane, but I'd really like to understand the rigging and process before we get there.
Thanks in advance!
Joe
Jun 1, 2004
8,360
You're correct about the issue with swept back shrouds. My Nacra beach cat was like that... If you have a crew they can most likely stand at the mast to hold it steady.. but that might intimidate some folks, and windy days may be problematic... My Nacra's mast was 25 feet, and raising it on the beach with two people was easy. By myself, however, posed challenges. I built a 3 legged crutch that would fold for storage in the cat box to hold up the end so as to get a good angle on the raising line... side to side... I used the trapeze lines clipped to either end of the main beam. Problem solved. OBTW, I also learned that for the trailer mounted winch to be effective, the boat must stay secured to the trailer and the trailer must remain hitched to the tow vehicle. :banghead:
I doubt that you have trapeze lines for your monohull, therefore something else is in order. I have seen diagonal struts, 3-5 feet long attached to either side of the mast, braced to the deck with pinned connectors... like something you'd use to rig a bimini frame. You could remove them easily when not needed. The ones I've seen are tubular, flattened on the ends to accept the brackets. You can also take a look at some of the Macgregor trailerables that have wire stays instead of the rigid tube braces. They call them "baby stays" which, of course, is not what a baby stay is... but I'll keep quiet lest I ruffle some feathers. Anyway... make a simple (mast raising systems) search.... and eventually you'll stumble across some YouTube vids that will illustrate the system.
Be patient, this subject is fairly common, so there will be plenty of wisdom shared, making it a certainty that you'll be able to raise and lower your boat's mast all by yourself in no time. Have fun.
Isn’t the 26.5 the same hull as the 260 but with a fixed keel and ballast instead of water ballast and a swing keel?
If so I’d think the mast raising system designed for the 260 and 26 would work just fine.
Apr 3, 2020
191
Thanks rgranger. Based on that video (Thank God for mute!) I would say the 26 and 26.5 are NOT the same hull. Certainly not the same topsides.
