Hello ODay Owners or those experienced with stepping a mast.
Does the mast boot provide for a hinge-like pin connection into the deck plate for a secure connection before it is raised?
I am very close to making a decision to purchase an ODay 272 LE, but before I do I need to know whether I'll be able to step the mast without the aid of a lift.
The boat's mast plate is a US-Spars Z-1175x and the mast Boot is a Z-260SF-10/2P (http://www.rigrite.com/Spars/SparParts/Sheaves.html). The seller's relied on a lift/crane to step the mast at his marina therefore he's never used the included A-frame system or explored the use of a gin-pole for mast stepping. If I purchase the boat, I want to be able to step the mast using a gin pole singlehanded as I've done before when I owned a MacGregor, but I'm unsure on how or whether the boot and plate can be connected securely before beginning to raise the mast.
Has anyone have experience with this mast boot and deck plate system.
Thanks
Thanks
