Rod Sheaffer
I had pulled my mast last yaer to replace a back stay and shroud paint and re wire. Also have a crack on the mast step. I have ground the top if the step off to get rid of the rotten coring and the glass on the side of the the step that is loose. Should I glass it all back in or use 5200 and then glass it back in. I am going to use phenolic to biuld it back up, plus 1/2 in. because of the 1/2 in. I need to cut off the mast.
