Early D model
I have an 87 D model. I do not have a slot in my tabernacle, rather I have a hole plain and simple. I always thought the slotted mast bases were for those who did not want to retension and adjust their standing rigging when trailering the boat, the slots allowing easier pinning of the forestay and reset of the standing rigging for those who adjust their sidestays and never touch the adjusters again. If tensioned properly, the upper and lower sidestays are probably going to make standing up the rig more difficult.I do not think that in any case the mast should touch the top of the cabin. The slot may be too long, allowing the mast to bind when it goes overcenter. And knowing the Macgregor boat building design frugality, I doubt that the slotted tabernacle is stock anyhow.If your mast butt binds on the deck below as you raise your mast, and if you combine that with a block and tackle to raise the mast, you have a recipe to create the kind of stress that deformed the pictured mast butts.A proper shoe and reciever plate casting, such as the ones on higher priced boats, will never be installed by Macgregor at the factory. The binding problems will be eliminated when the mast is supported away from the deck. Ask me how I know.....
