Last winter I found that my mast step had cracked. I assume it was due to metal fatigue and temperature change as the boat was covered with a tarp and the mast removed for the winter. I took the step to a local machine shop and got a quote for $350 to make a new one. They said the piece could be welded back on but I prefer to replace it given the load that the step bears under sail. The part number is difficult to read. It looks like '83756 STEP'. My question is does anyone know if Hunter or an after market supplier sells these. If so, a company name and contact info would be appreciated. Thanks Steve.
