Has anyone had experience with broken turning blocks connected to studs in the cast aluminum mast step? The studs have broken the mast step and pulled out.
I have a cure for the broken mast step. I have also made a pattern so that anyone else who has a similar problem can have the same cure. A photo is attached showing the repaired mast step. The new item is much stronger and can now safely take the strain of multiple turning blocks.
