Common Problem
Deck compression is a common problem on the C30. Practical Sailor noted that almost every 30 they encountered had compression of 1/2" or so. It's typically caused by the rig being tuned down too tight; related problems involve water seeping into the plywood core under the mast step, causing saturation, delamination of the plywood, or worst of all, rot.Practical Sailor, and most surveyors, seem to indicate that the problem is not severe if there is no indication of cracking of the deck around the step, delamination of the deck, or cracking/ delamination of the interior hull liner under the mast step. Check for all of the above. Also check the entire "compression sandwich" supporting the mast below deck -- the compression post itself, and very importantly the wood mast step/block in the bilge which carries the mast stresses to the keel. This block has a tendency to soften after prolonged exposure to bilge water.Catalina has an excellent spec sheet on the mast step repair and also on replacement of the bilge mast step/block. I recommend you contact the factory and obtain them for further info. The basic repair involves unstepping the mast, removing the deck step, using a hooked tool to pull up the compressed fiberglass deck, insuring there is no delamination/rot of the plywood core, and injecting epoxy into the void. I've talked to one owner here who had it professionally done for $300 and it looks pretty good.My '81 has about 1/2" compression but no cracks or signs of delamination; I intend to have it fixed when I replace the standing rigging, this year or next. I have some softness in the bilge mast step which I intend to treat with injected epoxy; if that doesn't firm it up then I'll go the replacement route.Unrelated to deck compression, but just as important, of course, is to insure all your stays/shrouds are in good shape and your chainplates adequately secured.Hope this answers some of your questions. Perhaps some of our fellow owners with first-hand experience with the repair will share their experiences as well. Good luck!Mike TurnerS/V Amity
